May 30, 201015 yr right clutch is starting to slip again, now I was told ages ago that you need to use different oil than recommended in a Thunderace because of the clutch? also when in fifth gear I pull the clutch lever all the way in and it disengages but then re-engages after a few seconds is that right? or normal?
May 31, 201015 yr Rather than using special oil ... I would get a barnett racing clutch and springs ... thereby solving you entire clutch-slipping issue and allowing you to run a high quality syntheic or other high quality oil in your engine ... Karen right clutch is starting to slip again, now I was told ages ago that you need to use different oil than recommended in a Thunderace because of the clutch? also when in fifth gear I pull the clutch lever all the way in and it disengages but then re-engages after a few seconds is that right? or normal?
