Techie Information
Fellow Riders
I wrote several articles in the general section
I was told those articles are better posted here
Rather than crosspost them which is a big time no-no
I am just going to post the links to articles I wrote
You can go ahead and peek at them there if you wish to
Rubber Side Down
Karen
Just a follow up to include ... that is all ... this is my introcution I wrote to this board ... since most of you have read it you do not have to read at it all ... I am merely including this as part of the compilation of technical articles I have written thus far to keep them in one place ...
Because I know "just a little" about motorcycles and the fact that
An engine is essentially an air pump of a combustible mixture
Regarding air - it is not "sucked" or "pulled" into the engine
There are no little hands reaching out grabing air molecules
Air may only be pushed into an engine it is never pulled into one
The air pressure at sea level is 14.7 pounds per square inch
On the intake stroke carb and intake valve in the open position
The piston is travelling downward creating a void inside the engine
Thus there is an "empty space" being made inside the engines cylinder
The 14.7 PSI pressure on the opposite site of the carb and valve
PUSHES AIR into the empty space created by the downward travelling piston
Thus in order to increase the amout of air a given engine can pump
Its design must maximize airflow this is known as volumetric efficiency
Or the air pressure into the engine be increased via super or turbo charging
The same is true for a vacuum cleaner or any other such device air is pushed in
Another board asked me to write an article on purchasing your first bike
For the discussion I used motorcycle racing as the primary topic
That an understanding of the machine itself may thereby be obtained
Thus making selection the device best suited to your purposes easier ... Karen
http://www.youtube.c...h?v=yTgyBmdD4f4
http://www.youtube.c...h?v=7X08zELY-lo
http://www.youtube.c...h?v=6Mfwv_GwhFs
http://www.youtube.c...h?v=vURjSJi5Zjk
http://www.youtube.c...h?v=7x7lwPzayHI
Moto GP / F1 Racing Engines
Engine revolutions fourteen thousand rpm at starting line
Rider slips clutch out torque / not well at low rpm
Large drop in RPM as engine propels bike from start
Once motorcycle returns to proper rpm range
Must at all times be kept there by selecting correct gear
Usually between eight and fourteen thousand rpms
http://www.youtube.c...h?v=-NHEAxKGw8Y
http://www.youtube.c...h?v=btnOW31bg14
As motorcycle begins to move it is held upright
This occurs at very low revolutions through gyroscopic precession
Imagine a bottle tied to a string you hold in your hand
The bottle and the end of the string is one inch above the ground
You begin to spin in a circle and as you do so the bottle rises
Once you are spinning fast you feel the tension rise upon the string
That is because the atoms in the bottle are being "thrown" away from you
The only reason the bottle remains is the strength of the string
Exceeds the tension the bottle applies to it however
Should you let go of the string or the string should break
The bottle will fly away ... this is what occurs in a motorcycle wheel
The only difference is that it occurs in a vertically instead of horizontally
Here as in discuss you have made yourself the axis about this the item processes
http://www.youtube.c...h?v=sEW1ZsSCVHE
http://www.youtube.c...h?v=IEwAry0GARw
http://www.youtube.c...h?v=8H98BgRzpOM
http://www.youtube.c...h?v=pF_SUvPAOSs
To test this to the following ...
Get an old bicycle wheel
Put a bar through where the axle was
Use some duct tape on the bar to keep it centered
Have a friend spin the wheel fast as you hold it
Now try to turn the wheel to the left ... it does not
The wheels force shall alter direction and flip over
Here she is trying to turn the wheel to the left of right
When she does you shall see what occurs.
This is gyroscopic motion / inertia
What is important to realize here other than what you see
Is that these people are not "flipping the wheel over"
They are with their hands attempting to turn it to the left or right
The flipping to the side you see is the gyroscopes resistance to that
Thus is is important to remember a motorcycle is not a car
It is a system based upon two spinning gyroscopes
Therefore it reacts as one and must be driven that way
http://www.youtube.c...h?v=TSC6e2e5lQw
http://www.youtube.c...h?v=_VAavF8EJzw
http://www.youtube.c...h?v=eLRFsy0fOTE
http://www.youtube.c...h?v=YzgUiremOtw
Directed forward rider pushes bars away from direction of turn
Wheels act as gyroscopes countersteering leans bike into turn
First Law of Motion: Body in motion persists in a straight line
unless compelled to change
This is one of the hardest for new riders
Also many riders are not taught this
And even experienced riders may argue this
However the fact remains to steer a bike to the left
You must push the handlebars to the right
To steer a motorcycle to the right
You must turn the bars to the left
This is not only important to turn at high speed
If you have a car coming at you from the right
And you are travelling over ten miles per hour
You must turn towards the object
If you own a bicycle find a hill and ride down it
Get the bike going fairly quick and very very gently
Turn the bars to the left and you will turn to the right
Or push on the left handgrip go left
I am including this to such a great degree
Because if you ride a bike you MUST understand this
In racing we use this to "throw the bike over hard"
This allows us to dive into a turn steeply
I am including this with some degree of intensity
There is also a myth that a motorcycle is turned by leaning
I do not recommend you try this unless you are an experienced rider
Even then you may dump your bike however as a demonstration
I one time leaned far to the left knee down and
By countersteering turned the bike to the right
Thus leaning is a part of turning but there is more to it
That is how the racer throws the bike into the turn so quickly
Because if you ride a motorcycle it may save your life one day
http://www.youtube.c...h?v=oVa2Ax-Dins
http://www.youtube.c...h?v=M1A7o-aXvqU
http://www.youtube.c...h?v=s8M_7fBR63Y
http://www.youtube.c...h?v=v5AmFGioYDg
Ok so that is how the racer throws the bike down into the turn so quickly
Braking = Kinetic Energy and thermodynamics
From wikipedia
The kinetic energy of an object is the extra energy which it possesses due to its motion. It is defined as the work needed to accelerate a body of a given mass from rest to its current velocity. Having gained this energy during its acceleration, the body maintains this kinetic energy unless its speed changes. Negative work of the same magnitude would be required to return the body to a state of rest from that velocity.
Friction is not a fundamental force, as it is derived from electromagnetic force between charged particles, including electrons, protons, atoms, and molecules, and so cannot be calculated from first principles, but instead must be found empirically. When contacting surfaces move relative to each other, the friction between the two surfaces converts kinetic energy into thermal energy, or heat.
In other words energy was applied to accelerate the object
Thus energy must be applied to slow the object
In machinery we use frictional energy converting motion to heat
Which it possesses due to its motion
The kinetic energy of a single object
Is completely frame-dependent (relative)
For example, a bullet racing by a non-moving observer
Has kinetic energy in the reference to frame of this observer
But the same bullet has zero kinetic energy to itself
Thus at steady speed the motorcycle applies zero kinetic energy to the rider
For the rider is not part of the same travelling system as the motorcycle
However this becomes a completely different situation
Slowing motorcycle from 200to 40 mph via brakes
frictional conversion of forward momentum / energy to heat using
Through the use of advanced ceramic materials
http://www.youtube.c...h?v=D8MsuFHlc54
http://www.youtube.c...h?v=m1dv_y_3EK0
http://www.youtube.c...h?v=L8pnaRpDU1A
The idea in racing unlike in road riding is this
On the road you want to brake in a slow and smooth motion
Taking your time slowing the bike easily
In racing you want to brake as late as you possibly can
Hammer on the brakes and then get back on the throttle
However there are severe issues in motorcycle braking
1: if you are hard in a turn braking will want to throw the bike over
2: This is called highsiding where the bike flips you over itself
3: Not too many braking examples however it is common in racing
http://www.youtube.c...h?v=KREIjnk6jTI
http://www.youtube.c...h?v=kGdU6ypYXD4
Yet another issue is the independent front and rear brakes
Thus you must balance the force applied to both brakes perfectly
On the front brake if you apply it wrong and use
To much force and you shall go over the front wheel
http://www.youtube.c...h?v=ARdw0WrV_gE
Or you shall put the wheel into a skid throwing you down
However much more common is the rear wheel lock up
Though I do not have vids of that if you have ever seen
A motorcycle try to stop quickly and the rear wheel go everywhere
You see the read wheel slide all over ... the rider must counteract that
http://www.youtube.c...h?v=BZqXPhK_3LE
http://www.youtube.c...h?v=kfmWx0tYRV8
http://www.youtube.c...h?v=s0P3tYskn84
http://www.youtube.c...h?v=HBm_L5Xt780
Also we do not have windshield wipers
Remember unlike on a car where you can stab the brakes
On a motorbike even in a panic or in a race
You must perfectly modulate the brakes or you will crash
You can easily crash through improper braking alone
Furthermore remember the ONLY thing keeping you upright
I gyroscopic precession. Thus should you lock up a wheel
Even at 60 MPG there is nothing keeping you upright at all
Therefore as the racer brakes they must do so perfectly
On both wheels in order to slow the bike correctly
Centrifugal Force:
As you turn certifugal force wants you to go to the outside of the turn
lean angle of the motorbike counteract the force pushing you to the outside
Here is where Chemistry comes into play for unlike the older days
Today the advanced compounds in the tires allow lean angles to 60
Degrees-Very fine line between optimum cornering and crashing
Outward and downward forward forces balanced precisely
You must consider the camber of the curve to determine speed
You must also know if it is a decreasing radius curve as well
One other common issue is called going wide on the turn
To lean a motorcycle hard over is frightening it feels like falling
So due to this fear to do not throw the bike over hard enough
By this choice you do not make the turn and you drift wide on the corner
http://www.youtube.c...h?v=Hx7RvfukIG4
http://www.youtube.c...h?v=mTnKkdIfVXQ
http://www.youtube.c...h?v=cq9Ua5Tuw3Y
http://www.youtube.c...h?v=5wYD9SSBBNQ
http://www.youtube.c...h?v=sN3bD4U5yJ4
http://www.youtube.c...h?v=W16hsnIur1Y
http://www.youtube.c...h?v=QCg3BMGe52M
http://www.youtube.c...h?v=3aW01UaHyC4
http://www.youtube.c...h?v=7mHTzOskcQE
Thus a motorcycle excellent example how physics work
A motorcycle at a constant speed
defined as "v" for velocity in motion
Is about to enter a level, circular, curve
The curve is defined a r for the radius of the curve
The radius r lean angle from the vertical position
Is approximated by the following relationship
First I shall need to explain theta ...
Theta ... Theta is used When determining the measure of the angle in the work equation, it is important to recognize that the angle has a precise definition - it is the angle between the force and the displacement vector. An explanation would be applying a force to displace a motorbike up a hill to the top of the hill. A force is applied to a bike to displace it up the hill at constant speed. Say 30 MPH.
Several incline angles are used progressively steeper thus you must increase the force to maintain 30 mph. However do not forget that the force is always applied parallel to the incline. And the displacement of the motorbike is also parallel to the incline as well. These are defined a F for force and D for displacement. Since F and d are in the same direction, the angle theta in the work equation is 0 degrees. For they are in a relationship of zero degrees to one another. Nevertheless you may wish to experienced the strong temptation to measure the angle of incline and use it in the equation. Do not do so because angle. It is defined as the angle between the force and the displacement vector.
Next issue is the definition of Tangent
Tangent is as follows ... a straight line or plane that touches a curve or curved surface at a point but does not intersect it at that point ratio of the opposite to the adjacent side of a right-angled triangle ... Tangent line to a curve at a given point is the straight line that "just touches" the curve at that point ... Tangent plane to a curve is the plane that contains
all the lines tangent to a specific point on a surface
The equation for it is as follows
tan (\theta) = \frac {v^2} {rg} where g is the acceleration due to gravity
What this means is as follows ... the speed of the bike and the weight of the bike, the radius, displacement, and camber of the turn shall determine the amount you lean and balance the bike to thereby counteracting the centrifugul force trying to make you go wide on the turn allowing you (provided you do not exceed the frictional capability of the tires in doing so) to steer to the apex of the turn properly and set the bike for the next turn.
Thus when people ask me what should my first bike be. Sure the common answers would be
The Ninja 250r
http://www.kawasaki.....ns.aspx?id=431
The Suzuki Tu250
http://www.suzukicyc....egory=standard
The yamaha V Star250 (AN EXCELLENT BEGINNERS RIDE OF HIGH QUALITY AND BEAUTIFUL FINISH)
http://www.starmotor....89/0/home.aspx
The Honda 250 rebel
http://powersports.h...2009/rebel.aspx
However here shows how to ride your motorcycle as this person is doing ... taking an extremely common and well made street bike (the Ninja 250r which I plan to purchase and am already set up with the dealer to do) onto the track and showing what a little 250cc street bike can do when ridden by skilled riders ... on the track ... not on the street ...
http://www.youtube.c...h?v=y2HnEld-z3Q
Rubber Side Down
Karen
Karen" you are far too inteligent for the bikers on here, Are you a geniusunsure.gif , whats your day job,???
Thank you sweetie :)
There is not better or more appreciated compliement than anyone could give to me than ... "genius" you really know how to touch a girls heart.
After fifteen years in motorcycles (which before I got into I took one year of college for mechanical engineering) ... I decided to go back to college and get an AA degree in computer programming / repair ... my day job is network administrator for a health care facility. Though they are shutting down and relocating which I decided not to do ... so now I am just a Biker Chick.
Karen
Clicky clicky ;)
Like the new flag picture ... and also the Clicky Cliky ... though are you implying I am fast forward or fast behind :)
Clicky clicky ;)
