Ello people
Just wondered if anyone knows of a cheaper/better option for the oil return pipe for me old cat, I'm sure it's not actually supposed to be made from pure RUST lol!
The only one i can find is on e-bay for £25! Item no.120545499880. I thought oil pipes would be the same fitting from 96 through 2000 but they say they can't garantee this so now i'm unsure!
Any help appreciated! Cheers!
Isn't it fun changing the Cats front sidelight bulb! lol! :blink:
As far as your direct OEM replcement pipe I do not know where one is ...
However an issue we use in customizing ... which may at all times be referenced ... is the virtually unlimited world of industrial brass ... through wich just about any oil carrying conduit you can imagine within your head ... may be created ... Thus while I would at all times recommend going with an OEM part ... should that part be completely unavailable ... for that which you need to do ... there is an industry of fittings out there ... whose entire purpose ... is to allow any custom application to be created ...
http://www.dbwcopper.com/images/fitting-reducer2-.jpg
http://aksharmetal.com/pipe-fittings/brass-pipe-fittings1.jpg
http://product-image.tradeindia.com/00296089/b/0/Brass-Pipe-Pipe-Fittings.jpg
http://vatsalyametal.com/images/Brass-Pipe-Fittings-Sanitary-Connector-Parts.jpg
Rubber Side Down
Karen
  On 30/05/2010 at 10:02, MadHatter said:
Ello people
