thundercat
we have a problem with clutch on p reg thundercat there is no pressure at the lever it felt like cable had snapped....cable is not snapped (checked it) still attached when i took casing off...now we are stumped any help ? please
Replace casing, remove the rubber bung on the outside. You,ll see a screw & locknut. Slacken the locknut. Turn the screw clockwise until it seats lightly. Unscrew it a quarter turn & tighten locknut. If this doesn,t sort it you,ll need to take a look at the clutch itself. (BTW are you sure the cable is ok?). Hope this helps.
