yzf 750 brakes
hello everyone im new to all this i have had a quick look, i have a 1996 yzf 750 and want to fit blue spot r1 ront brake calipers on does anyone know do they fit straight on and what year to go for many thanks to everyone jim
i think they will require some light filing. I fitted gold-spots to my fzr1000 (which has similar/the same forks) and had to do some filing for them to go on. When you do this check the contact patch of the pad on the disk carefully, as you may need to allow a clearance for the bobbins on the disk.
good luck
