Hi, the later dtr's have the same rear mudguard as a DTX with the brake light built in on top which looks much better than my early version where the rear light is just above the number plate.
will the later mudguard fit my 2001 dtr ?
cheers
2 stroke ray :)
cheers
2 stroke ray :)
You mean the DTRE? Will the DTRE rear mudguard fit a DTR? As far as i know, no. I beleive the fittings are quite different. They remodelled it quite alot to accomodate the light being in the mudguard to give it more of a motoX style look. Im sure if you have the right tools you would be able to make it fit, but then the lights might be compatible.
