TZR50 won't start on electric starter
Hi, hope someone can help.
Just bought a 2004 TZR50 for my son and it refuses to start on the electric starter, but will bump start instantly. Fitted new plug, cleaned carb. Fuel and spark are present when trying to electric start, but it just refuses to fire. I'm no expert on 2 strokes, but thought it maybe a lack of speed from the starter, so to eliminate poor battery tried operating starter using jump leads from car battery straight to the starter but still no joy.
If I do a compression test what pressure should I see?
Any ideas on a cure?
You could have something like clutch drag or the like, putting extra weight on the engine, worth checking things like that out.
Does sound like the starter is not spining fast enough for fire-up.
Dont know what the compression should be !
Thanks 2 wheels, hadn't thought of clutch drag, not sure how i'll check it. Do you know what type of inlet valve this engine uses? Is it a rotary or reed type? As I said 2 strokes are not my forté and i'm just starting to find out about them. Thought are that it could be a leaking reed valve. The bike had not been used for around 1 year prior to our purchase.
To check clutch drag--- get the bike started, then get the back wheel off the ground, select 1st gear but dont let the clutch out. If the back wheel sparts to spin slowely or even makes an attempt to spin then you have clutch drag.
Im pretty sure you have a reed valve on that bike. If the bike will bump start and runs good then dont go messing with the reeds or the carb unless you really have to. If you suspect you have an air leak then look for split or damaged pipes arround the carb and the reed assembly, spray wd40 round them and listen to the engine, if it starts to idle better then you have an air leak.
Is it the not starting on the button that is your only prob? Lazy starter from lack of use, spray with wd40 everywhere you can get in at it.
If the bike hasnt been used for a year then your gona have a few wee probs every now and again so expect them, go for a good old spin down the road to blow off the cobwebs!!
Best plan of attack to find out any probs/ or indeed cure them is to get using the bike everyday if possible !!
Hope this helps
Hope this helps
OK, latest status.
Before I received your latest message my son and I had whipped the tank, carb and reed valve out. It looks like new, a carbon fibre valve with Conti racing written on the flaps (maybe this is a make local to here in France, and is the same as the silencer). Sucking and blowing through it seems to be fine. Refitted, no change, still won't start on the button, but first turn on a push start.
Stripped starter down, all appears fine, clean, no burnt commutator segments and, to be honest, it spins the motor over at a speed I would think is OK.
Compression test using a tester designed for car engines, we got 95psi dry and 125 psi with a squirt of oil in the cylinder. How does this sound? Seems a bit low to me on the dry test, maybe worn rings, but would this translate to the starting problem.
Clutch drag, tested using your method and there is some, but we are trying to start it in neutral as per the manual so I can't see it would affect the starting.
Any ideas gratefully received as I think the next step will be an engine strip down and new rings/piston/cylinder.
OK, latest status.
95psi doesnt seem that bad for that engine (tzr 50). Getting 125psi with a squirt of oil---- you are always going to get more psi when you do this, even on good piston rings. Do you know how many miles are on the bike ??
If she starts first go on bump start then i think you are just making work for yourself by stripping the head to check the rings. That said you could do it and give it a good de-coke while your at it!!
I would sort out the clutch drag first, i know your starting in neutral but for some reason the starter cant cope and wont let the engine fire-up.
Again more use of the bike and the starter, might free everything up and she might start to gradualy firing up on the button. Thats what i would try first before you go stripping the head.
Thanks again 2 Wheels for you input.
Bike has only covered 10,000 miles in total and 2,500 since new crank, oversized cylinder and piston (+0.5mm). The seller told us some tale about the crank getting bent when it was in a minor accident, but on thinking about it, it seems more likely to me that it was run out of oil. Anyhow, unless it has been allowed to run out again , then yes the piston/bore should be fine. I am car man of over 40 years experience, so this sort of mileage is nothing in my view, but I do realise that perhaps these small bike engines have a hard life and i've read somewhere that this TZR50 model is a bit fragile.
My son doesn't come of age to take it on the road till next week but he has been running it around our property for half hour sessions to get it well warmed up a few times.
We will look again at the clutch drag and carry on running it as you suggest and see what happens.
Poor lad was hoping to have it all sorted for his birthday, but on the plus side, we are both learning a lot.
Compression test suggests at best...worn rings. you should try new ones. How many miles (kms) has it done?
Will it start after a small quirt of oil is introduced?
No it didn't. I was hoping it would as well
It sounds like electrical to me, if it starts fine by bumping it then every other component works, so leave alone for now.
If the starter is turning the engine then you need to see if the coil is getting 12 volts while cranking, if not then there are two possibilities.
1- the starter solonoid is knackered.
2- The starter switch on the handlebar is not making good contact, this can be checked and cleaned to eliminate this.
If you are good at wiring then take a feed from the battery staright to the coil and see if this works...... if so it is your solonoid.
Thanks Peter T.
I think I have eliminated electrical problems as we have a spark when cranking, even tried with old plug held to cylinder while new one was in place therefore testing at real cranking speed (but not under compression).
We have connected a car battery straight to the starter while all else was set as for a bump start and still no joy.
My final conclusion is that the starter cannot turn the motor fast enough. We reckon that it needs around 700rpm to start on a bump start and the starter can only achieve around 4-500rpm. I believe this bike uses a Minarelli AM6 engine. Can anyone confirm this?
Looking on ebay there are numerous sellers of replacement starters for the AM6 engine so I guess they must get weak. The permanent magnets must be losing strength.
EDITED to add:
Removed starter again and re-oiled, connected it on battery in free spinning state and let it ruin on and off for few minutes. Seems fine so re-installed and connected car battery (car engine running) across bike battery and cranked for some time and it did free up such that I had around 800rpm indicated but it still stubbornly refuses to catch. It sounds promising but just won't fire. Disconnect jump battery and it bump starts immediately.
What is going on??????
With the clutch cover off it seems very easy to turn over by hand on the flywheel, but as I have said, I have little experience of small 2 strokes, so I don't know what it should feel like on compression.
Any more ideas anyone?
Edited by Caussados
looking for possible lack of compression, I took the cylinder off today and all looks fine. Cylinder still has honing marks and piston has machining marks. Only has one ring and that still has an even step around the top edge; so I don't think that is worn. As I mentioned earlier, the engine has only done 2500 miles since a re-bore and new piston. There are however score marks in line with the edge of the gudgeon pin on both the bore and the piston but I can't see they have caused a problem. I have seen diagrams that show circlips to hold the gudgeon pin but this engine does not have them. Anyhow, I will eliminate compression problems.
Does anyone know the torque for the head bolts? I've done them up to 10Nm as they are only 6mm bolts; Is this OK?
Earlier in this investigation, and partly why I wanted to take head/cylinder off, I found a pipe of around half inch diameter hanging loose under the air box then saw a suitable place for it on the clean side of the air box. It comes from a small rectangularish box fixed to the frame. There was evidence of muddy water having entered the air box via the open hole so possible muck in the engine. Does anyone know what the device is? It has an input pipe fitting of about the same size as that to the air box but I can't see a pipe to fit.
so you've had the engine apart, seen score marks on the cylinder wall, seen diagrams that show clips that will prevent this scoring but chose to ignore that and re-built the engine, is this correct? :o
Cylinder head nuts torque 17Nm M7 nuts...thats a weird size but I suppose m6 would be a bit small.
Items to tighen Number Thread pitch Tightening Observations
torque
Nm m•kg
Spark plug 1 M14 x 1.25 23 2.3
Cylinder head
Nuts 4 M7 x 1.0 17 1.7
Cylinder
Bolts 4 M8 x 1.25 18 1.8
Coolant draining plug 1 M6 x 1.0 5 0.5
Water pump cover
Screw 3 M6 x 1.0 5 0.5
Thermostat bolt 2 M4 x 0.7 2 0.2
Water pump
Bolt 2 M5 x 0.8 7 0.7
Carburetor joint
Screw 4 M6 x 1.0 10 1.0
Crankcase (left right)
Screw 13 M6 x 1.0 10 1.0
Bolt 4 M7 x 1.0 12 1.2
Crankcase cover 1
Bolt 5 M5 x 0.8 5 0.5
Crankcase cover 2
Bolt 4 M6 x 1.0 10 1.0
Crankcase cover 3
Crankcase cover 1 2 M5 x 98 4.5 0.45
Oil drain plug 1 M8 x 1.25 17 1.7
Intermediate shaft
Nut 1 M12 x 1.0 60 6.0
Clutch
Nut 1 M12 x 1.25 75 7.5
Screw 4 M5 x 0.8 4 0.4
Push rod nut 1 M14 x 1.25 27 2.7
Shift pedal
Screw 1 M8 x 1.25 30 3.0
Starter motor
Screw 2 M6 x 1.0 10 1.0
Flywheel 1 M10 x 1.25 52 5.2
torque
Nm m•kg
Cylinder head
Cylinder
Water pump cover
Water pump
Carburetor joint
Crankcase cover 1
Crankcase cover 2
Crankcase cover 3
Intermediate shaft
Clutch
Shift pedal
Starter motor
Yes, I have reassembled the engine and can confirm the bolts are in fact M7 but with a 10MM A/F nut. Having taken the cylinder and piston apart I am prepared to to repeat this operation when I get some circlips, in the meantime I am still trying to find the reason for the inability to start on the electric starter. Looks like the only step left is to replace the starter.
Many thanks for your torque data and valuable input.
You really do need to fit those circlips asap.
I'm wondering if you are losing your spark when cranking with the starter.
1: The spark plug specification is
BR9ES/1 piece
Manufacturer N.G.K.
Spark plug gap 0.6 ~ 0.7 mm
Set yours to 0.6mm
2: If still not working try this
attach a car battery in parallel to your bike battery
+ to + ........and - to -
see if this makes any difference, if it does you may only need to replace the battery, not the starter. replacing the starter will be expensive and if it is cranking the engine , replacement seems unnecessary to me.
New plug is in place, one of the first things tried.
Plug gap is nearer to .6mm than .7 but I don't have a true .6mm feeler gauge.
Checked spark while cranking and today removed plug suppressor to give best possible spark.
Also tried old plug connected to lead and held to block while new plug in place to simulate real crank speeds, but spark obviously not under compression.
Previously tried paralleling with car battery and again today, with car engine running.
None of the above will start the engine on the electric start, but a push start and it's away.
The electric starter will crank at between 500 and 800rpm, bit I don't know if this is fast enough as the quoted idle speed is 1600 to 1900rpm.
I'm running out of options other than to buy a new starter.
  • 3 weeks later...
PROBLEM SOLVED!!
The motor had been fitted with a "performance piston" with only one ring (mentioned above) and it turns out that the electric starter will never give sufficient speed to start such a configuration. So, given that the cylinder was scored due to lack of gudgeon pin circlips, I decided to replace both piston and cylinder with a standard type (2 piston rings). It starts and runs well now. Close examination of the old piston also showed that it was cracked, so that wouldn't have helped.
We got the information from the local Yamaha agent who immediately spotted the problem when I described the engine to him when I went in to get the gudgeon pin circlips.
Many thanks to all who offered suggestions but it goes to show that you never know what you are getting with secondhand stuff.
Now to change the gearbox oil, brake fluids and put 2 new tyres on and it may be ready for the road.
All my son has to do now is pass his test!
