Posted May 17, 201015 yr Hi Chaps, A newbie here...any one give me a sarter on what's wrong with this DT125 i just bought, it will start but only when bumped off and runs really rough...where should i start? Cheers Woz
May 17, 201015 yr Moderator Hi Chaps, A newbie here...any one give me a sarter on what's wrong with this DT125 i just bought, it will start but only when bumped off and runs really rough...where should i start? Cheers Woz You just bought it eh...Woz it cheap An interesting post title 'lost of compression' well i'm thinkink if the compression is lost then that could well be the problem, in fact almost certainly. However I suspect this is just a typo and it has lots of compression If this is the case and you have only just bought it is there fuel in it and are you leaving the choke in the on position because it will run rough if this is the case. ...Paul
May 17, 201015 yr You just bought it eh...Woz it cheap An interesting post title 'lost of compression' well i'm thinkink if the compression is lost then that could well be the problem, in fact almost certainly. However I suspect this is just a typo and it has lots of compression If this is the case and you have only just bought it is there fuel in it and are you leaving the choke in the on position because it will run rough if this is the case. ...Paul Could be loss of compression. Typo's are such a great means of comedy. http://bp1.blogger.com/_B5pRQyW8dNs/SJAAP2a4smI/AAAAAAAAAWU/8qebXL8FNUQ/s1600-h/typo4.jpg
