May 15, 201015 yr Hi all, I noticed a rattle and the heat shield turned out to be loose dude to a broken/worn through bracket/hose clip. I clean it up and found a hole about 2mm under where the clip was. I have a welder and was going to try to fill/cover the hole. Does anyone know a good fabricator that has mode custom pipes for Dragstars? Cheers
May 16, 201015 yr Hi all, I noticed a rattle and the heat shield turned out to be loose dude to a broken/worn through bracket/hose clip. I clean it up and found a hole about 2mm under where the clip was. I have a welder and was going to try to fill/cover the hole. Does anyone know a good fabricator that has mode custom pipes for Dragstars? Cheers highway hawk
