May 13, 201015 yr Evening all, Just a quick question for all you DT fans ! I'd like to know what you think of doing a steady 60mph for about an hour or so on a dt125 (my lil bike) Do you think i will be killing my lil engine ? I'd like to think not but im not sure ! What ya think.
May 13, 201015 yr Top o" the mornin to yeh" [ irish accent] , The dt shud handle it, good quallity oil, [ check] and settup [ mixture] as long as you dont hold it flat out, for long spells, Also running out of fuel [ swiching to res] can lean a two-stroke out. go for it,
May 13, 201015 yr Moderator I'd like to know what you think of doing a steady 60mph for about an hour or so on a dt125 (my lil bike)
May 13, 201015 yr Author Top o" the mornin to yeh" [ irish accent] , The dt shud handle it, good quallity oil, [ check] and settup [ mixture] as long as you dont hold it flat out, for long spells, Also running out of fuel [ swiching to res] can lean a two-stroke out. go for it, Aye blackhat, hows it going !! You reckon it is up to the job. Think i have mixture setup right although the 2stroke oil does seem to drop a bit quick, but better that way than not enough, eha! Didnt know that putting to res would lean out a stroker ---- learn somethin new everyday.----- cheres for that !!! Hey OG, what you think, you dont sound convinced that no harm will come to it ?
May 13, 201015 yr Moderator Aye blackhat, hows it going !! You reckon it is up to the job. Think i have mixture setup right although the 2stroke oil does seem to drop a bit quick, but better that way than not enough, eha! Didnt know that putting to res would lean out a stroker ---- learn somethin new everyday.----- cheres for that !!! Hey OG, what you think, you dont sound convinced that no harm will come to it ? it's be fine Pat 60 isnt thrashing it by any means...but you have a 600 cbr?...why not that?
May 13, 201015 yr Author it's be fine Pat 60 isnt thrashing it by any means...but you have a 600 cbr?...why not that? A yes, indeed i do but, as it is getting rough arround the edges, just passed 60,000miles and is a 98 bike with a bit of tidying up to do on it(im not realy one for washing me bike)----- i am thinking into the distance of when the time comes to change to a newer model, if my lil dt will get me passed for the time it takes me to source another bike ! And then, o what, o what, o what will i go for next !!!
