Posted May 8, 201015 yr Can anyone give me details of the above engine,currently fitted in an XS360 frame,is it 250 or 400?
May 8, 201015 yr Author there's a 1L9, never heard of a that one. xs250 only with 3n6 What did the 360 and 400 codes come out as?
May 8, 201015 yr Author 1L9 = XS360 1T6 = XS360 1U6 = XT500 11G = XS1100 1L6 = LB50 Thanks for that but its definately an XS twin of 250/360/400 family,it was described as a 360 but it is not round barreled,as I thought it should be.
May 9, 201015 yr Moderator Thanks for that but its definately an XS twin of 250/360/400 family,it was described as a 360 but it is not round barreled,as I thought it should be. it'l be a 360 then, round barrels came after the D models and usually were "custom" type of bike!!
May 9, 201015 yr Author it'l be a 360 then, round barrels came after the D models and usually were "custom" type of bike!! As I'm trying to built a 'period ' type of bike and the round barrels would suit the style bettr,could I substitute round barrels for the square ones?
May 9, 201015 yr Moderator As I'm trying to built a 'period ' type of bike and the round barrels would suit the style bettr,could I substitute round barrels for the square ones? yep, but you'll have to use 400 pistons and head/rocker cover. why not cut the fins? I know it sounds sacrelige, but i recon its do-able
May 10, 201015 yr Author yep, but you'll have to use 400 pistons and head/rocker cover. why not cut the fins? I know it sounds sacrelige, but i recon its do-able Head ,rocker cover, barrels and obviously pistons anything else?,I am actually hunting round for alternative pistons to give a capacity nearer the 500cc mark,anyone any 'tips' or well known mods for that?
May 10, 201014 yr Moderator Head ,rocker cover, barrels and obviously pistons anything else?,I am actually hunting round for alternative pistons to give a capacity nearer the 500cc mark,anyone any 'tips' or well known mods for that? i posted a few pictures on the forum of a 450cc conversion i borrowed the pikkies off german ebay a few years back. you need to use the search facillity!
