2nd question ,,brake master cylinder
tonytony
This post is 5316 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Evening All
I have a 2nd question in as many days...
Yam xvs 650 1997 front brake master cylinder kit
Does anybody know if/where I can get some new seals for front master cylinder as Yamaha want to charge an arm, a leg and a pint of blood..
In their infinate wisdom Yamaha made these seals VERY special..
My brake seal stockist says that on measuring the 2 seals some dimensions are metric and some imperial
My measurements for the 2 seals are...
1st seal (small) is od = 13mm,,,,,id = 5.75mm,,,,,, height = 3.5mm
2nd seal (larger) is od = 13mm,,,,,id = 7.8mm,,,,,,, height = 4mm
Hope someone else has had the same problem and found a solution
cheers
Tony
Hi There,
Thanks for reply,,
I've just tried the site and it covers a lot of models but doesn't show mine,
so I've emailed them but they haven't replied
Many Thanks
Tony
