May 4, 201015 yr hi ,i have broken the lower engine mounting lug on my engine badly , all the oil came out , i have sourced another short engine with barrels and pistons , no ridges so i think it should be ok , my question is , what is easier to build up the replacement using my original engine parts or change the lower case over?
May 4, 201015 yr hi ,i have broken the lower engine mounting lug on my engine badly , all the oil came out , i have sourced another short engine with barrels and pistons , no ridges so i think it should be ok , my question is , what is easier to build up the replacement using my original engine parts or change the lower case over? My guess, you have no idea what that other engine is/was like so i would replace the lower case !!!
