Best Way To Bleed Brakes on a DT125R
Hi,
I just would like to know what the best way to bleed the brakes would be as i have got new break pads and havnt made any difference after I had bleeded them so which is the best way to bleed ??
Many Thanks,
Paul
Hi,
Many Thanks,
Paul
Just fitted a goodridge braided fron line to mine.
Remove reservoir cap. fit clear plastic tube to bleed nipple and punch a hole into a jam jar cap.
Pass the clear tube to the bottom of the jar.
top the reservoir up to its upper level.
Stand on the left of the bike.
Pull the lever 3 times and on the 3rd pull do not release it.
Open the bleed nipple with your left hand, you will see dirty fluid come out, maybe air bubbles too., also the lever will continue to move to the handlebar.
When the lever stops...close the nipple.
Repeat the process but keep a check on the level in the reservoir.
...Paul
Excellent Cheers for quick reply mate appreciate it :) ! will let u no how i get on tomorow !
