April 26, 201015 yr Moderator has changed everything in the clutch slip a bit when the engine is cold help So, you have fitted the 170kit and now the clutch is slipping? The clutch should just about handle it if it is in good nick, make sure it is properly adjusted so it isn't holding the clutch open and causing the slip. If everything is adjusted ok then you will have to strip and check the clutch. If it has been slipping for a while then you will most likely need to replace the friction AND the metal plates as the metal plates warp very easily(personal experience), its worth changing them out to get the best from the big bore. Finally with the new clutch a set of heavy duty springs will really help. Good luck..
April 26, 201015 yr the clutch slip a bit when the engine is cold help WHAT Oil you using ? [ not car oil] also av heard bead blasting the steel plates can help ,, more friction ,,
