April 24, 201015 yr i was out on my 81 Yamaha xj650 , when it started acting funny , loss of power , sputtering ect , seemed VERY hot , letting her cool down for awhile and ill check it later , pulled the plugs and all 4 are burning normal , not wet and oily , anything else i should check ? thanks
April 24, 201015 yr Author just checked it , was a little low , bike is cool now and was checking for loose connections , still running funny , almost like a backfire out the right exhaust
April 24, 201015 yr Moderator Sorry i'm not familiar with the specific bike, Has something come loose, check exhaust connections, is the exhaust corroded and blowing anywhere ? is it a points ignition system, maybe new point and capacitor (condenser) are needed, also check ignition timing.
April 24, 201015 yr Author waited a few hrs and checked everything again , oil was very low , added some and let her cool down and everything seems to be back to normal , good idle and the sound is strong again , i used to work on my little 150cc scooter , and traded it for the bike , 08 scoot for a 81 bike lol , cant go wrong , the bike seems to be built like a tank , thanks 4 the help
April 25, 201015 yr Author turns out it was the petcock valve , was screwing with it today and put it to prime , so the valve or the vacuum line is shot , works great on the prime position
