NSU Bison 2000
drewpy
This post is 5338 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
This is the world’s largest single-cylinder two-wheeler. It was built by a gentleman called Fritz Langer, and it’s based on an NSU Konsul 500.
Fritz replaced the original cylinder and piston with a 122 ci unit from a radial aeroplane engine, but that piston weighed 3.3 kg—over 7 lbs. So Fritz got Mahle to make up a lightweight piston of just 1.6 kg. After the engine block was widened and the crank milled, Fritz was ready to roll.
The stainless steel exhaust system, incidentally, is 75 mm (3 inches) in diameter, and there’s no silencer. So it’ll be enough to put even a Screamin’ Eagle-equipped Harley to shame
<div style="width: 400px;"><object type="application/x-shockwave-flash" data="http://www.gaskrank.tv/tv/intradat/etc/player/gaskrank.swf?image=http://www.gaskrank.tv/tv/intradat/branding/playbg.php&logo=http://www.gaskrank.tv/tv/intradat/etc/player/t1.png" width="400" height="320" wmode="transparent" flashvars="file=http://files.evisor.tv/200708/1451.flv">
<param name="movie" value="http://www.gaskrank.tv/tv/intradat/etc/player/gaskrank.swf" />
<param name="wmode" value="transparent" />
<param name="flashvars" value="file=http://files.evisor.tv/200708/1451.flv&image=http://www.gaskrank.tv/tv/intradat/branding/playbg.php&logo=http://www.gaskrank.tv/tv/intradat/etc/player/t1.png" />
</object>
<div style="text-align: center; font-size: 10px;"><a href="http://www.gaskrank.tv/tv/motorrad-oldtimer/bison-lebt-teil-2-1451.htm" target="_blank">Bison lebt - Teil 2, NSU Bison 2000</a>
<br>powered by Gaskrank.TV</div>
</div>
