April 14, 201015 yr After a few days of riding she has snapped which is not that much of an issue for me as the bike will run even better when i find one...i say..where would you find one? Cant source on on ebay as well as the internet shops i have looked in..throttle clutch and break cables seem to be the rage-the only one for a dtr on ebay is for an older version..suggestions would be valued cheers for your time-ross.
April 16, 201015 yr After a few days of riding she has snapped which is not that much of an issue for me as the bike will run even better when i find one...i say..where would you find one? Cant source on on ebay as well as the internet shops i have looked in..throttle clutch and break cables seem to be the rage-the only one for a dtr on ebay is for an older version..suggestions would be valued cheers for your time-ross. Any Yamaha dealer, i bought two new ones for around £9.
April 17, 201015 yr Author Thanks:)After replacing the power valve cable she now wont idle or ride unless chock is on...the carb was taken apart and cleaned when it was rebuilt..it has been problem after problem so far im lost as to what it is now
April 17, 201015 yr Moderator Thanks:)After replacing the power valve cable she now wont idle or ride unless chock is on...the carb was taken apart and cleaned when it was rebuilt..it has been problem after problem so far im lost as to what it is now After replacing THE powervalve cable, whats the other one like and how freely does the pv opperate, and is the motor opperating ok too. It takes a lot of power to bust a cable, more than the little pv motor is really meant for. I would give it more than a cursory look.
April 19, 201015 yr Author the cable had frayed over time causing it to snap-the other one is 100%. i put a new carb on there today which has taken care of the idle issue it now rides without the choke on..i can use it for transport at least the problem now is first and second gear give the expected power delivery but after that its crap. it used to pull through every gear to 70 and sit there fine today its a struggle to hit 50,when you open it out through the gears the engine behaves and sounds like its stone cold-you know the horrible weak sound, i have adjusted the carb its made no difference...any ideas,thanks
April 19, 201015 yr Did you check that the jet sizes in the carb you put on are the same as the one you took off? This would be the first thing to check.
April 21, 201015 yr Author Problem was the "reconditioned carb" was not so clean i got it from a garage so never gave its quality a second thought-lesson learned-sorted that carb ran fine but the power valve was still destroying the bikes power beyond second gear so i have put it in the open position and disconnected it- it now has a poor bottom end yet when the power kicks in its the fastest its ever been infact if id have known i would have done that a long time ago- i am happy job done
