FZ6 S2 warning lights
any advice apreciated - my 08 fazer which is just hovering on warranty expiration keeps showing warning lights as follows - coolant and engine management lights on constantly, immobiliser light comes on intermittently, (which stops me starting up engine of course)but this generally goes after a couple of attempts, display panel shows : error code ER1 - temperature H 1 degree C.
back to yamaha dealer initially who diagnosed u/s voltage regulator and changed same, putting out all these warning lights but two weeks later they are all back.
Any one with similar experience, I ride throughout year so had fair dose of rain, water penetration possible cause?
Not had any problems with my Fazer S2 If I was you I would take the bike back to the dealer, riding in the wet should not make any difference, bikes are made to be ridden in the wet or dry. As the bike is still under warranty the dealer has a legal obligation to fix it.
Acid drop
yes that is the plan, slight problem, the immobiliser and its warning light now on full time so unable to start to get to dealer cannot beat the computor! bring back the old days of simple elctrics, never a murmur of a problem on my old fazer
will post results of dealer diagnosis when obtained
