Posted April 12, 201015 yr Hi everyone in new to the site and been enjoying my 97 Thundercat. The problem i have got is that while i was setting the rear shock to standard settings everything was going fine until i was changing the rebound (counting the clicks),i heard a "PING" now theres no clicks and not changing to the movment of the adjuster.Adjuster just seems to just spins on the thread. The Shock really sits and pushers at the top of the travel (as though the rebound is quite high) with wooliness and doesnt settle(wholloing,like being on a waterbed).I've adjusted the rest of the the bikes settings to get around it/ not make shock the setting unrideable. Questions, Is it easily fixable? Is the standard shock rebuildable? Who could do it? (i live at the boarders of Lancashire and Yorkshire). Are there any compatable shocks that will do as a replacement? Say Is a R6 shock of same age will fit? Thanks
April 15, 201015 yr Hi everyone in new to the site and been enjoying my 97 Thundercat. The problem i have got is that while i was setting the rear shock to standard settings everything was going fine until i was changing the rebound (counting the clicks),i heard a "PING" now theres no clicks and not changing to the movment of the adjuster.Adjuster just seems to just spins on the thread. The Shock really sits and pushers at the top of the travel (as though the rebound is quite high) with wooliness and doesnt settle(wholloing,like being on a waterbed).I've adjusted the rest of the the bikes settings to get around it/ not make shock the setting unrideable. Questions, Is it easily fixable? Is the standard shock rebuildable? Who could do it? (i live at the boarders of Lancashire and Yorkshire). Are there any compatable shocks that will do as a replacement? Say Is a R6 shock of same age will fit? Thanks
April 15, 201015 yr hi sounds like you have broken something internally, the best advise i could give is ebay, there is a company on there there will refurb a shock for £100, or alternativly you could do what i done and buy a 2nd hand one from there it cost me £15 in total. hope this helps
April 24, 201015 yr Author hi sounds like you have broken something internally, the best advise i could give is ebay, there is a company on there there will refurb a shock for £100, or alternativly you could do what i done and buy a 2nd hand one from there it cost me £15 in total. hope this helps Thanks. Got something else to look at, Engine/gearbox casings and a swing arm,oh joy!
