Xvs 125 Shifting to third and upwards
Hi all,
I started my xvs up last week after about 5 months and had it on a bike jack. The gears changed no problem. I started up this week and cannot get it above second gear. First second neutral is all fine. I rode it up for a mile to warm it up thinking it may be the clutch plates but still no joy even when engine is hot. Any ideas?
have u tried adjusting ur clutch? mine used to lock up on a long ride and stick in one gear then i found out the clutch cable had stretched and loosened it.
hope this helps if not iv got a load of parts if u want to buy some cheep. the con rod in mine went about a year ago and i couldnt get it fixed.
. Paul.
Change the oil & filter.
My mate spoke to his friend who said it's to do with the shifting rod sticking due to standing and condensation getting in. He said force it in which I did'nt like. So I eased it in by putting trying to push the pedal up and releasing and eventually in went into third. From then 4th and 5th was no problem. I had it on a bike lift and ran it in each gear. Took it for a spin and now shifting is no problem. Just to add the oil and filter was changed last June.
LAST JUNE??!!
OK, so it was changed, ridden a bit and has been left standing for 5 MONTHS....
What happens to a cup of coffee if you leave it standing for 5 months?
Trust me - Change the oil.
yeah id say go with Ttaskmaster! poor oil is what destroyed my engine!! it was only 4 years old and only did 14000 miles! dont let it end up in boxes in the shed like mine is!
