1976 DT 175
Hi.
I am getting my 1976 DT 175 back on the road. All is well (believe it or not) except for:
1. Flasher relay - the thing lights up the flashers but will not flash (on and off) - even when revved. Any one know where I can get a replacement? It has three connections; brown, white & brown and black.
2. Petrol tap inner filter if fcuked - replacement needed.
3. (The big one) the petrol tank needs repair - best options? (other than a replacement tank which are as rare as rocking horse shot).
If anyone can help, be much appreciated.
If I can get these sorted I may even put it up for sale.
Thanks.
Pkay
Hi PKay,
Depends where you are but you should be able to get a suitable flasher relay from a motorbike shop. With the old parts, some shops are not so good with supply while others have bits that suit the 6v. Maybe I'm lucky but a shop close to home had exactly what I needed and it wasn't expensive.
Haven't had to get a filter for the tank but I reckon you should put a filter in the fuel line anyway and that would probably suffice.
On tank repair, depends on what you need to do. Minor hole or to or a little rust shouldn't be too much of a problem but if it's too stuffed you'd be better off getting it replaced. The DT was relatively common so they are around somewhere.
Hope that helps.
Gordo
Hi Gordo - thanks for that.
Yes, I supose a bike spares shop (or internet) should locate a flasher rely; why didn't I think of that?!
The fuel filter also - just put one in the fuel line - job done!
The tank; as far as I can see (following internet searches) is that there are no replacements available. (Found one in the states but the shipping costs were ridiculous - especially as I couldn't be sure it was the model I need).
So will have to look at repair.
Thanks for the response.
PK
