PKaysYam Posted April 8, 2010 Share Posted April 8, 2010 Hi. I am getting my 1976 DT 175 back on the road. All is well (believe it or not) except for: 1. Flasher relay - the thing lights up the flashers but will not flash (on and off) - even when revved. Any one know where I can get a replacement? It has three connections; brown, white & brown and black. 2. Petrol tap inner filter if fcuked - replacement needed. 3. (The big one) the petrol tank needs repair - best options? (other than a replacement tank which are as rare as rocking horse shot). If anyone can help, be much appreciated. If I can get these sorted I may even put it up for sale. Thanks. Pkay Link to comment Share on other sites More sharing options...
DTGordo Posted April 9, 2010 Share Posted April 9, 2010 Hi PKay, Depends where you are but you should be able to get a suitable flasher relay from a motorbike shop. With the old parts, some shops are not so good with supply while others have bits that suit the 6v. Maybe I'm lucky but a shop close to home had exactly what I needed and it wasn't expensive. Haven't had to get a filter for the tank but I reckon you should put a filter in the fuel line anyway and that would probably suffice. On tank repair, depends on what you need to do. Minor hole or to or a little rust shouldn't be too much of a problem but if it's too stuffed you'd be better off getting it replaced. The DT was relatively common so they are around somewhere. Hope that helps. Gordo Link to comment Share on other sites More sharing options...
PKaysYam Posted April 9, 2010 Author Share Posted April 9, 2010 Hi Gordo - thanks for that. Yes, I supose a bike spares shop (or internet) should locate a flasher rely; why didn't I think of that?! The fuel filter also - just put one in the fuel line - job done! The tank; as far as I can see (following internet searches) is that there are no replacements available. (Found one in the states but the shipping costs were ridiculous - especially as I couldn't be sure it was the model I need). So will have to look at repair. Thanks for the response. PK Link to comment Share on other sites More sharing options...
