April 3, 201015 yr hi all im wantin to replace the rear lights with custom led's built into the fender but need it to pass an mot. dus anyone know about the regulations on lights and what would pass and what wouldnt? cheers. Paul .
April 3, 201015 yr so long as its secure, works without affecting other lights it will pass. You need a reflector if it hasn't got one in the lens.
April 3, 201015 yr Author well the idea is to have a rear light setup that is invisible till the lights come on so it just looks like a fender i was going to use super bright LED's mounted directly to the fender but wasnt sure if it would pass an mot. and by reflector do u mean the little red ones or the silver one that goes behind the bulb?
