April 2, 201016 yr I HAVE GOT A 2002 YAMAHA DT 125, I HAVE HAD IT FOR ABOUT 3 WEEKS, LATELY WHEN I HAVE BENN PUTTING IT INTO FIRST GEAR IT JUST CUTS OUT INSTANTLY, AND ALSO WHEN IM IN ANY GEAR AND IT WILL CUT OUT IF I DONT KEEP THE REVS UP. ANY SUGGESTIONS ON WHY? THANX
April 2, 201016 yr Moderator DONT TYPE IN CAPS!! I suggest you investigate the switch on the sidestand or the connections to it may be loose. Get a multimeter and test its operation. ...Paul
