06 650 Classic Starting problem
I need some wisdom and figured this was the place! My '06 650 Classic has been garaged all winter and high and dry. I charged the battery and then started her up. But every time I go to close the choke a bit, after the bike seems warm, it shuts down-like it's not getting gas. I checked everything I can think of: air cleaner, etc. and took everything apart looking for mice nests etc. -none of that. It's also making a kind of mechanical "clicking" noise when I turn the key. Almost like you would hear with a car that has a dead battery, but the bike starts. It just won't keep running without the choke wide open. I shot a phone video to get the sound and will send it along to anyone who would like to take a shot at diagnosing. I'm baffled and so is my friend who is pretty good with bikes. It's almost like a fuel pump, but I don't think the bike has pump (thus the choke, right?). Ideas? and thanks for taking a look at my post.
The clicking when you turn the key is the fuel pump.
It should stop after a few second when the carb is full. If you tun the key but forget to switch the petrol on it will 'click' for England. :rolleyes: Yes I've done it.
Have you riden it to get it warm or just on the stand - it might not be warm enough.
Try new petrol too.
How long are you letting it warm up?
I give mine a good minute, every single morning. I take that minute to go round, giving it the POWER check:
Petrol
Oil
Water
Electrics
Rubber
Or, in the case of Cruisers, W = Weather B)
Some Winters, I also turn the idle up just a touch, depending on how cold it is that year.
Thanks for the replies. I am going to try some things this weekend. I'm letting it warm up for more than a minute on the stand and the gas is "on". I am going to add some "new gas" and maybe try some carb cleaner. Will keep you posted! I welcome all suggestions!
