kellermann turn signal problem
Guys/Girls,
i need some help here...
I installed 4 LED turnsignal indicators, and a kellermann variable load relais, which is suited for use with LED signals.
I connected the 2 back LED indicators, and the front ones still original bulbs. everything works fine.
Now connected up the front LED's: indicators are steady (left or right).
If i hook up the original bulb together with the LED: works fine.
So looks as if still the load is wrong, but all the reviews i see for this relay say all working fine.
I'm sure i connected everything the right way.
Anybody experience with this relay? I connected the ground, constant 12V and variable 12V wires from the relay.
thanks
Peter
yes, maybe...
i tried with a light bulb in parallel, and then it works. So what this kellerman relay advertises seems not to be correct.
Guess i'll add 2 resistors..
But that was what i wanted to avoid in the first place, so the money i spend for this relay was a waste. Pfff
thanks
Peter
you will need resistors mate the minute LED lightenign is involved might need 2 minimum to resolve this problem.
yes, i tried it with the bulbs.. 2 resistors will do the trick.
Just pissed at this kellerman thing. They claim it works with 4 LED blinkers. And reviews of some people say works without problems...
Probably there's a difference in LED's also.
thats why ive only got led side light bulbs and tail light bulbs the rest is filament on my bike equals the power useage .
