March 26, 201015 yr Ideas wanted please, my dt seems to tick over too high and whatever adjustments are made at the carb make no difference. It has a new throttle cable, running a standard airbox and I'm sure there's no air leaks. thanks
March 26, 201015 yr Moderator Ideas wanted please, my dt seems to tick over too high and whatever adjustments are made at the carb make no difference. It has a new throttle cable, running a standard airbox and I'm sure there's no air leaks. thanks Have you set the adjustment on the new cable properly so it isn't holding the slide up? Has it happend since the new cable or was the cable supposed to fix it? How are you sure it has no air leaks?
March 26, 201015 yr Author Have you set the adjustment on the new cable properly so it isn't holding the slide up? Has it happend since the new cable or was the cable supposed to fix it? How are you sure it has no air leaks? Hi, I actually took off the throttle cable and started it but still the same. I suppose it must be an air leak. Cheers
March 26, 201015 yr Moderator Hi, I actually took off the throttle cable and started it but still the same. I suppose it must be an air leak. Cheers What is she idling at? WD40 works quite well as a leak detector. Zap all round the inlet side of the motor and see if the engine note drops. Failing that try and spray behind the flywheel as this is another favorite leak spot on DT's, ie the left hand crank seal. When the other side gives trouble you get a lot of smoke as a rule.
March 26, 201015 yr Author What is she idling at? WD40 works quite well as a leak detector. Zap all round the inlet side of the motor and see if the engine note drops. Failing that try and spray behind the flywheel as this is another favorite leak spot on DT's, ie the left hand crank seal. When the other side gives trouble you get a lot of smoke as a rule. will do. Thanks
