Hi everyone, wondering if anyone has knowledge of how to remove restrictor kit on my 2005 Fz 600, I passed my test 2 yrs ago so can't wait to get kit removed and feel the extra power. Local garages charge £50 - 60 to remove, so I thought if it wasn't to difficult I would remove myself.
Any help would be welcome.
Paul
I cant say for certain but its most likely to be a 'draw' type restrictor, these come in various different forms,
the 'draw' type can be found in the carb rubbers (intake side) and restrict the induction (sucking) oooer Mrs, ;)
most of them look like large washers stuck into the carb body :mellow:
My fz 600 is the injector fed model, don't know how they restricted it, I have searched internet for info but as yet.....
  • 3 weeks later...
Hi,
My 2005 FZ6N has a throttle limiter attached to it. The haynes manual appears to show that it might be straightforward to remove, but as yet I have not plucked up the courage to try it myself. The restrictor kit is an "Alpha Technik RJ07" but a quick google search did not turn up anything useful.
Good luck with it and if you do manage, I would be very interested to know how you got on - my dealer wants over £100 to remove it...
Cheers,
Gogs
Pablo - Your current licence shows the restriction so don't forget to get it changed and updated by DVLA or you risk a fine. It is not automatic as some people think.
You may need to check out the threads on here about 'lost' licences before you rush to send it off.
Cheers
