March 21, 201016 yr Not a question - just an observation. I'd manage to source a replacement airbox for my Radian sometime last year - finally got round to having a go at fitting it today. Unfortunately, I discovered that when they built these bikes, they started with the airbox and then built the entire bike around it....I'd dismantled virtually everything, and after a couple of hours trying to bend ease it out I gave up - seems the only way to get that baby out is to take the engine out. I fitted new carb holders whilst I was at it. Now it won't start.....there's always tomorrow I suppose (once the battery has re-charged...)
March 22, 201016 yr Author OK - I do have a problem. Managed to get it to start after a lot of coaxing. However, it won't idle. The adjustment screw on the back of the carb doesn't seem to do any good - I think the choke is making some difference, but not enough to keep it going. I haven't touched the setup on the carbs at all - all I did was take them off, and replace them again. I'm guessing the system is more airtight than it was as I've replace the carb holders that look a bit perished - unless somehow I've got something wrong and it's less airtight. Any ideas?
