Hi,
New member here, but an old rider !
My '75 DT-250 jumps out of 3rd gear
on acceleration. A Yamaha dealer
told me if he "remembered correctly,
there was some sort of detent for
adjustment" behind the cover, but
wasn't positive. I know I need a
new clutch, as I am nearly maxxed
on adjustment. But I would think that
once it's in gear it shouldn't pop
out, in spite of the clutch issue ?
Can anyone shed any light or suggestions?
I have recently moved and don't have
the web at home yet, so doing a little
Saturday research at work. Will be here
for another 5 hours, would really appreciate
any help.
Thanks in advance.
There is a detent but its just to control the actual movement of the selector drum. If its jumping out under acceleration then its the torque forcing the gear out of position and that can only happen if the dogs are worn.
Sorry i can't give you a better answer :( , if there is anything that may help blackhat will know...
Thank You for the quick reply Cynic,
I was afraid of that....!
