Posted March 15, 201015 yr i have a dragstar 1100 and am wanting to remove the air induction system, does anyone know where i can buy the kit to block the pipes?
March 16, 201015 yr i have a dragstar 1100 and am wanting to remove the air induction system, does anyone know where i can buy the kit to block the pipes? there are plenty of kits out there debi some will require you re jet and retune here are a couple of links. VStar_AIS_No_Air.pdf'>VStar_AIS_No_Air.pdf http://www.sscustomcycle.com/products/engine/v-star1100.shtml http://www.vstar1100.com/jack_phelps/vstar/ais.htm hope that gives you some ideas as to what to do and whats available theres plenty of information out there if you google, paul.
March 16, 201015 yr i have a dragstar 1100 and am wanting to remove the air induction system, does anyone know where i can buy the kit to block the pipes? You can buyy these from Baron Custom www.baroncustom.com, or if you'd prefer to source from the UK, we can get you a kit when we next order from them. It costs around the £30 mark (if that). Alternatively, you could fit their oil filter relocation kit, which from memory comes with the AIS removal kit too. This costs around £260, but you'll save a fortune in labour trying to get to the oil filter to begin with and it's a top quality bit of kit that comes chromed. Hope this helps, Roy
