xj700 engine swap
i have an 86 xj700 maxim , i`m taking the engine out to replace all seals and plate (she runs lovely so won`t mess with her to much), whilst i`m doing that i will fit another engine so she don`t hav to be off road .
a friend of mine has an xj900 pre diversion engine he said i can have , i have been told these go straight into my frame hmmmmm , i`m not 100% sure about this so does anyone out there know ?
keep safe dusty
Hi a1dusty,
Not too sure about the Maxim as it was not a UK model, but a friend of mine tried a similar feat with an XJ750 and XJ900. The engine fitted in the frame fine, sure, but the carbs/airbox were a right old game (i.e they didn't fit !!). So you may well have similar issues with your Maxim.
Best regards, IO.
Hi a1dusty,
Best regards, IO.
hi io
thanks bud , was hoping to get away with using me 700 carbs , will hopefully give it a go
this weekend .
thanks again
dusty
  • 5 months later...
hi io
this weekend .
thanks again
dusty
You could probably use the 700 carbs, but they need to be rejetted to compensate for the increased amount of airflow / fuel consumption...
