Hey I am trying to figure out where i can buy larger jets for my carbs so that i can run the air pod filters. I have been doing alot of research but i cant seem to find anyway that sells what i need, If anyone has some ideas please tell. Thanks
You should be able to find those jets at your local Yamaha shop.
I have an 82 xs400 maxim - (don't know what the difference is if any for the carbs) I have found jets for mine on ebay. They are Mikuni Carbs. Search for - Mikuni Main Jet N100/604 -
here is a link to a 130 (recommended to me by another guy on a different thread for running pod filters)
http://cgi.ebay.com/ebaymotors/NEW-MIKUNI-MAIN-JET-N100-604-VM-HS-HSR-TM-CV-XS-H1-130_W0QQcmdZViewItemQQhashZitem588671488fQQitemZ380212693135QQptZMotorcyclesQ5fPartsQ5fAccessories
I haven't got mine done yet but hopefully by this weekend.
  • 4 weeks later...
Thanks Guys i ended up just going up to the Yamaha dealer and ordering some.
Is there a huge advantage to Pod air filters over the stock?
Also I remember someone saying Uni air filters end up better than the pod's for some reason on a recent thread here (forget the reason why)...
My mechanic removed my filters so need to buy new ones. Think my 78 XS400 bike that i bought last year has a 2-1 aftermarket exhaust, guessing they are the Mac ones since they are only company I see making them.
If I do install pod or uni, will the carbs definately need to be rejetted or it just will be '5%' off and air/fuel screw will be enough to compensate for that?
Thanks!
I have ordered pod filters for my XS500 because the stock air-box was missing when I bought the bike. I live in Denver at 5300 feet, is it possible the increased air from the pods will be counterbalanced by the reduced air density at altitude? Or will I likely need to re-jet as well?
that's a great question, LostCost. I'd like to know the answer too.
I do know that a stock fuel mixture is usually good up to 3000ft at least. But since these bikes usually came from the factory lean, they should be on for higher altitudes.
:icon_question:
