Posted August 3, 200421 yr Hi guys, I'm new here and into biking. Happy to see some Yamaha fans out there. I just bought a FZ600 1988 and I'm currently repairing fairings (they were in BAD shape). Since I'm actually doing some work anyway I figured out it would be a good idea to change the tail light on it for something more appealing. Some of you guys know a light that would fit quite easily there to replace the current one. Another questions for you guys while your at it . You guys know where I could find a lower left fairing for my FZ. Used or new who cares as long as they are in good condition and not too expensive. Found one on e-bay but the guy says it's guide only specifies that the fairing is compatible with 86-87. Thanks BeerBaron
August 3, 200421 yr Moderator :hi to the Forum BeerBaron Does your FZ have the dual headlight set-up?.....just curious :wink: Can't remember what year they changed that
August 3, 200421 yr Author Yes it does have two headlight up front... Really like the look of those BeerBaron
August 3, 200421 yr Moderator Yes it does have two headlight up front... Really like the look of those BeerBaron You & Me Both :wink:
August 11, 200421 yr I only know that you can't fit LED bulbs in the back becasue the hole is too small.
November 8, 200717 yr I only know that you can't fit LED bulbs in the back becasue the hole is too small.hey jimjam,you will find those panels on e bay mate,cheers,tufty.
November 8, 200717 yr hey jimjam,you will find those panels on e bay mate,cheers,tufty.hey beerbob,just realised i posted the reply to jimjam when it was you who posted,anyway the panels you want are on e bay uk mate,i think i need more kip,cheers,tufty.
