February 28, 201015 yr hi can any one help need wireing harnees for a dt175 mx 1981 2k4 been told its a 1978? also a voltage regulator a wireing diagram would help. thanks nigel
February 28, 201015 yr Moderator hi can any one help need wireing harnees for a dt175 mx 1981 2k4 been told its a 1978? also a voltage regulator a wireing diagram would help. thanks nigel Voltage regulators are on Ebay for around 20 notes. Look, http://cgi.ebay.co.uk/Yamaha-DT100-DT125-DT175-DT250-Voltage-Regulator-QR498_W0QQitemZ310177918810QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item48380b6f5a You need to find out for certain which year. There is a critical difference between the ignition systems between 78 and 81. The cdi units on the earlier bikes use 2 coils on the stator and a 7 wire cdi the later bikes use 1 coil and have 6. Its a red one thats deleted. It isn't a problem so long as the stator and the cdi match, you can add the extra wire in there if you need it. As far as looms go, this any good to you..... http://cgi.ebay.co.uk/YAMAHA-DT125-DT175-4J3-WIRING-LOOM-HARNESS-1980-1-QH019_W0QQitemZ310198712539QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item483948b8db
