yamaha xt 125 x 2007 rear wheel bearings
Jay22220286
This post is 5321 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
does anyone know where i can find out what rear wheel bearings i need for a yamaha xt 125 x 2007 bike as mine are damaged and for the life of me i cant find what i need to replace them with. thanks. jay
You prob need to measure the old ones and then just buy any ones that suits
Here is an example of what you are looking for.
I.D = internal diameter
O.D = outer diameter
W = with
Wheel_Bearing_rear_left_hand_I.D_20mm_x_O.D_42mm_x_W_12mm
Wheel_Bearing_rear_right_hand_I.D_20mm_x_O.D_42mm_x_W_12mm
Hope this helps !
there should be a number stamped/etched on them,you may see it better when you take them out, this is the ref. number
if there is no ref. number just take the bearing(s) to a bearing specialists, there are plenty of them, and he should have one to suit. this will probably be cheaper than going to yamaha.
hope this helps ;)
W = with
Hope this helps !
thank you for that!much appreciated. jay
hope this helps ;)
thanks thats been a great help. jay
