February 23, 201016 yr does anyone know where i can find out what rear wheel bearings i need for a yamaha xt 125 x 2007 bike as mine are damaged and for the life of me i cant find what i need to replace them with. thanks. jay
February 23, 201016 yr does anyone know where i can find out what rear wheel bearings i need for a yamaha xt 125 x 2007 bike as mine are damaged and for the life of me i cant find what i need to replace them with. thanks. jay You prob need to measure the old ones and then just buy any ones that suits Here is an example of what you are looking for. I.D = internal diameter O.D = outer diameter W = with Wheel_Bearing_rear_left_hand_I.D_20mm_x_O.D_42mm_x_W_12mm Wheel_Bearing_rear_right_hand_I.D_20mm_x_O.D_42mm_x_W_12mm Hope this helps !
February 24, 201016 yr there should be a number stamped/etched on them,you may see it better when you take them out, this is the ref. number if there is no ref. number just take the bearing(s) to a bearing specialists, there are plenty of them, and he should have one to suit. this will probably be cheaper than going to yamaha. hope this helps
February 24, 201016 yr Author You prob need to measure the old ones and then just buy any ones that suits Here is an example of what you are looking for. I.D = internal diameter O.D = outer diameter W = with Wheel_Bearing_rear_left_hand_I.D_20mm_x_O.D_42mm_x_W_12mm Wheel_Bearing_rear_right_hand_I.D_20mm_x_O.D_42mm_x_W_12mm Hope this helps ! thank you for that!much appreciated. jay
February 24, 201016 yr Author there should be a number stamped/etched on them,you may see it better when you take them out, this is the ref. number if there is no ref. number just take the bearing(s) to a bearing specialists, there are plenty of them, and he should have one to suit. this will probably be cheaper than going to yamaha. hope this helps thanks thats been a great help. jay
