Part required for YZF750R
Hi does anyone have or know where I can get the bush that connects to the exup valve below the manifold.
Just the bush itself that needed.
Tried wemoto,fleabay with no luck..
Do you mean the bush that the valve rotates in? Dunno if it,s available as an OEM part on its own. Used downpipes from a breakers, perhaps?
Yes the valve/bush that the exup valve slides into.
Tried various sites with no joy, is it necessary to have this as when I take the valve ot I can see the hole where the end of the valve
should go into, cant I just grease it up??
Is the valve assy. loose/rattling? Is the bush worn or missing? I presume it,s the bush in the manifold itself (i.e. on the right hand side).
Yes
Its the piece that goes onto the item pictured , like a bush/collar.
Would it be possible to get an engineering shop to make something to suit? I,d still reckon s/h downpipes would be your best bet as the manifold would have that bush in situ,as it were.
