oil pump
need help
how do you set the oil pump on a YSR80 and also the air/fuel mix
the bike runs good but at top speed its realy smoky/white smoke
thanks for any help or tips
Fisrst I'd look on here for a manual for that bike.
But usually there is a mark on the carb slide that you have to sych up with the line on the oil pump. This is usually done with the throttle in 3/4 open position. It doesn't often go out, any smoke is usually due to deposites in the exhaust.
thanks for the info
need help
You said in your first post that you use the YSR for town stuff. It may just need a good clear out, white smoke at high speed is generally the oil burning out of the exhaust when it gets hot enough.
My TDR did it to begin with and after a good blast with a mate that got it very hot (25mpg if you know what i mean) it looked like a red arrow for a couple of miles. Been fine since B)
thanks I guess I need to go and give it a good run,
