February 18, 201015 yr So guys I need some help. I cannot for the life of me find the brake rod adjusting pi.Hhere is a pic of what it generally looks like. Will the xs650 brake rod adjuster pin fit on a xs400?
February 20, 201015 yr So guys I need some help. I cannot for the life of me find the brake rod adjusting pi.Hhere is a pic of what it generally looks like. Will the xs650 brake rod adjuster pin fit on a xs400? You need the wing nut you highlighted.
February 21, 201015 yr Author sorry I highlighted the wrong part haha, it is part 14 on the picture I showed you. But the wing nut should be easily found in a hardware store right? Anyways I placed an order with mikesxs which is a 650 sight and bought some 54mm air filters since older 650's share the same carb I think. I also bought the pin that goes into the lever and it is expected to arrive at the 23rd. I will keep you guys posted if anyone is interested.
February 21, 201015 yr Moderator sorry I highlighted the wrong part haha, it is part 14 on the picture I showed you. But the wing nut should be easily found in a hardware store right? Anyways I placed an order with mikesxs which is a 650 sight and bought some 54mm air filters since older 650's share the same carb I think. I also bought the pin that goes into the lever and it is expected to arrive at the 23rd. I will keep you guys posted if anyone is interested. you could have made one!
