yzf r125 not starting
danlee1985
This post is 5227 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
started my bike up this mornin to go to work but it wouldnt start up. battery has not died as my front light come on n my dash display was working. whaen i got back from work i decided to check the spark plugs and to see if the engine is firing both where in good workin order. I don't no what to do next as i dont want to take it to a dealer unless i REALLY have to.
CAN ANYONE HELP
PLEASE
CAN ANYONE HELP
PLEASE
if the battery is fully charged and it sparking its got to be fuel related ,any more info you can give us is it trying to start cough splutter,etc
well wen i was on it the other day i was on the last fuel bar with it flashing. it then came up with the display of F-0.1/then 0.2 so on so on. i filled the bike back up and it went back to normal fuel gauge and mileage etc the bike at the moment is st 11,000 miles and it runs really well with no problems.
wen starting the bike it sounds like its ticking over with out any go
Does the bike have a fuel tap? If you ever run out of fuel you will need to set the tap to PRI (stands for Prime) position for a minute or two before setting it back to ON or RUN or RES
its probably self-priming as it is EFI.
CAN ANYONE HELP
PLEASE
Without trying to sound like a total idiot here, you did check the engine kill switch is off, just incase you have caught it without knowing? Sometimes its the most simplest things that we miss that saves alot of money, and embarassment.
