Help!
Bike will not run without the choke on. Jets replaced, could it be the float height?
Any suggestions welcome.
Cheers
assuming the air / box and filter are on the bike i would say blocked pilot jet, float height is 21mm though.
Cheers Chief,
yes, standard airbox etc, I soaked the jets in paintstripper, which obviously has'nt worked on both.
Thanks
Cheers Chief,
Thanks
Nail varnish remover is good, poke it with a nylon bristle pulled from a brush. use a magnifying glass unless your eyes are very young :)
Will do.
Thanks
Paintstripper is often quite a thick solution, even thicker than wallpaper paste, so unfortunately wont flow into the jet orifice and will just sit there
doing nowt :P
