This post is 4058 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Nice one Ken, dont bother about getting the red off, just sand down any rough spots and key the surface then simply spray it heat resist silver :thumb:
How much did it go for BTW?
I sold mine many moons ago mate :(
paid £20 posted for 3mb head - £70 posted for re-lined cylinder
ill look into the paint!
what sort of performance gain did you notice if any with the 3mb head? i cant get mine to go past 60mph i would be happy with 70mph so i could keep 60 constant without having to red line the bike i mean if the head does give it a little bit more snap off the mark ill go up a tooth on the front sprocket.
im just worried if i go up a tooth ill kill the acceleration!!
i like my little bike so i dont wanna ruin the ride
cheers
ken
Sounds like you got a bargain there Ken. Nice one. I've also fitted a 3MB head but did ride this particular bike without it as it was a non runner when i bought it. Mine will get to 70 (on the clocks) and I've not yet taken it to redline. My acceleration is still very good. I believe im on standard sprockets but never actually checked tbh. Keep us posted!
thats what i thought 70mph should be reachable in my opinion but ill not know what sprockets its running until i pull her to bits and check everything over!!
i have a 17 tooth front sprocket and i think ill get a couple more have a play about with it see whats suitable to me
cheers
ken
I had 80 downhill on a motorway, only once though I just wanted to see it off the clock :0
I'm far too sypathetic a rider normally and would be happy at 65 most of the time, after all those bikes have the frontage of a barn door!!!
thing is mine is on the red @ 60mph, if it could do 70mph i would be happy at 60mph all day - just feel as though im killing my baby lol
think it has been downgeared... bloody hell i hope i havent just got 5 gears lol - ive had a few cans and i cant remember hahaha
ill check tomorrow
ken
There are different clocks. Some have red line at 9.5krpm and some at 10.5krpm. Mine is 10.5kprm. My clocks are import clocks in kph. I've fitted a speedo converter on the back of the clocks so to get off the clocks i'll have to get to 140mph indicated. Do you reckon i should try :spin2: !
  • 1 month later...
hi all
Im confused can you put an servo on a 1989 dtr CDI ??????? sorry for being noob
  • 1 month later...
anyone know what this wire behind the clocks looks like or what colour it is mines an 03 it has a full dep just had exhaust off and looked up the port turned on ignition and can see about ten mill of the valve as it sets so am sure it could be opened a tad more.the valve seems to want to kick in around 7000rpm but then just coughs and splutters tried everything its a nightmare ,cheers
when you turn on the ignition and the pv cleans and then comes to rest it should then be smooth along the top of the port...it's all explained in here if you care to find it
hi mines an 03 dtr 125 valve is fully open upjetted n carb set up,anyone know what this rees switch wire looks like colour etc as from 1st to 4th its mental 70 mph in 4th gear and then 5th and 6th it drops outa valve and dies so i think it could be this ilustrious wire ,any help much appreciated cheers
hi all
Yes Jake you can, but it must be the earlier 3 wire servo, not the later 5 wire one
  • 6 months later...
airhead you seem to know about dts, soon as i get into 5th gear my bike has no grunt at all, it takes so long to hit the power band again dose the exhaust port have to be slightly open when the ignition is off or fully open? ive been seaching for weeks how to de restrict it its driving me mad
see post #232, all the info is in here
hello everyone i bought a 2002 dt in august at first it wouldnt hit the power bands but my friend had a play with the servo and eventually it hit the bands but max speed was only 60 65 mph it hits about 70 after i took the snorkle of the airbox and covered up a hole that was drilled by the previous owner and went alright all the way up until 4th then dosent hit the bands that quick i dont want my bike to do sily speeds just want it to get to 70 quicker any ideas what i can do ?
since august milieage is 12022 the performance was getting better the longer i rid it but that was after the powervalve was adjusted
