FZ 750 starter solenoid?
Just wanting to be sure I'm right here. On the starter solenoid 1 terminal is for the batt and is constant "hot", 1 goes to the starter only "hot" when starting, the other 1 is the switch and is only "hot" when you push the start button when triggers the washer inside to send power to the starter. It should be the same as an automotive system I would think. Am I right or wrong? Where would you look if the smaller trigger wire has power to it all the time like the batt side only lower volts? Either way I'm pretty sure the solenoid is bad considering I can't get it to engage the starter wire <_<
