BulliteShot Posted February 7, 2010 Share Posted February 7, 2010 I had an oil leak from the seal that is just below the clutch actuator pin attached to the clutch cable. I pulled the pin out of the housing, took out the old seal and replaced. Now when I push the pin back in, it does not engage the clutch. What do I have to do to re-engage this pin onto the push rod? I guess its not as simple to put back as it is to pull it out. Please help! Link to comment Share on other sites More sharing options...
