January 31, 201016 yr guy i bought bike off bodged a k and n air filter on that has proceeded to fall off. i priced up a standard system for 100quid or i cud get a cone shaped filter and attatch it straight on for less than 15quid. Any ideas or tips on whats best. Im wary of usuing a custom filter as it was sucking so much air in it would lose power and stall. Thanks x
January 31, 201016 yr Moderator guy i bought bike off bodged a k and n air filter on that has proceeded to fall off. i priced up a standard system for 100quid or i cud get a cone shaped filter and attatch it straight on for less than 15quid. Any ideas or tips on whats best. Im wary of usuing a custom filter as it was sucking so much air in it would lose power and stall. Thanks x In most cases a std air filter housing helps the bike perform at its best. Pod filters will work but really need jetting to suit and then are affected by the weather far more. Obviously when it rains it gets wet. And tbh only really suit racers as they work best at WOT, well thats from Richard the main man at Towcester Tuning Services, google em. I would have thought you could get something for less from a breakers.
