Peter T Posted January 31, 2010 Share Posted January 31, 2010 I have a 2004 DT electric start model which does not start while cranking. It only seems to start when the button is released? Is there a relay that controls the starting coil while cranking? Thanks. Link to comment Share on other sites More sharing options...
Moderator Cynic Posted January 31, 2010 Moderator Share Posted January 31, 2010 I have a 2004 DT electric start model which does not start while cranking. It only seems to start when the button is released? Is there a relay that controls the starting coil while cranking? Thanks. Have you tried charging the battery. It may have enough power to turn it over but not actually fire, then when you release the button the motor is spinning fast enough for it to catch. Well it would be my first point to look at. Welcome to the club. Link to comment Share on other sites More sharing options...
Peter T Posted January 31, 2010 Author Share Posted January 31, 2010 Thanks for the welcome. That was my first thought but have tried that and it is a new battery. Link to comment Share on other sites More sharing options...
Moderator Cynic Posted January 31, 2010 Moderator Share Posted January 31, 2010 Thanks for the welcome. That was my first thought but have tried that and it is a new battery. The next place to check would be battery and starter motor connections. Link to comment Share on other sites More sharing options...
Peter T Posted February 1, 2010 Author Share Posted February 1, 2010 Problem solved!!! I renewed the gearbox oil before i started to semi strip it down, and realised after using a paddock stand that the backwheel was spinning? After applying the brake i soon found that the clutch was dragging badly which is why it would not start easily. Strange as it was Semi synthetic oil that was advised by a Yamaha dealer. Going to try some non synthetic oil. Link to comment Share on other sites More sharing options...
Moderator Cynic Posted February 1, 2010 Moderator Share Posted February 1, 2010 Problem solved!!! I renewed the gearbox oil before i started to semi strip it down, and realised after using a paddock stand that the backwheel was spinning? After applying the brake i soon found that the clutch was dragging badly which is why it would not start easily. Strange as it was Semi synthetic oil that was advised by a Yamaha dealer. Going to try some non synthetic oil. Nice one, so we were right that it wouldn't go because of the current drain. Just the cause we were out on. Glad its sorted. Link to comment Share on other sites More sharing options...
Peter T Posted February 1, 2010 Author Share Posted February 1, 2010 Yes!! Just goes to show that some problems are not always related and you have to do some lateral thinking sometimes. Link to comment Share on other sites More sharing options...
Moderator Cynic Posted February 1, 2010 Moderator Share Posted February 1, 2010 Yes!! Just goes to show that some problems are not always related and you have to do some lateral thinking sometimes. Most important tool in the fault finding box, an open mind. Link to comment Share on other sites More sharing options...
Ryan09 Posted February 4, 2010 Share Posted February 4, 2010 I used to use Castrol MTX 10w40 done over 14000miles with 3 or 4 changes and was fine, would definitely recommend it. Link to comment Share on other sites More sharing options...
