gs360 Posted February 4, 2010 Author Share Posted February 4, 2010 Thanks BRB for your feed back and help. And Thanks to Drewpy for all your help with the engine. I'll post pics when I get it looking somewhat cool :-) Link to comment Share on other sites More sharing options...
Moderator drewpy Posted February 4, 2010 Moderator Share Posted February 4, 2010 Drew, I have a looooot of slack, I finally got the old girl running and took a risk shifting the tranny on the center stand, I had the adjustment screw at the very end. I will get a box spanner and do what you said, but will it take up ~10mm? should do Another thing, how do I NOT use a battery? I have seen a lot of bar hoppers, bobbers and cafe racers with no battery in it and I like the way it looks. no can do with the xs range need power to excite the field coil. if you ditch the starter, you could get away with a 4amp battery Link to comment Share on other sites More sharing options...
gs360 Posted February 4, 2010 Author Share Posted February 4, 2010 DAAAH!!! Anoyone know where I can a find a fuel tank damper? I have looked on bikebandit, cmsnl.com, oldbikebarn and ebay there are none to be found. It's part #12 from here Link to comment Share on other sites More sharing options...
Moderator drewpy Posted February 4, 2010 Moderator Share Posted February 4, 2010 DAAAH!!! Anoyone know where I can a find a fuel tank damper? I have looked on bikebandit, cmsnl.com, oldbikebarn and ebay there are none to be found. It's part #12 from here but not here 1L9-24181-00-00 DAMPER,LOCATING 1 XS360 C 1L9 4 left $14.55 http://216.168.60.165/speedandsportinc/Index.tpl and here http://www.pgmyamaha.com/mk109.html Link to comment Share on other sites More sharing options...
gs360 Posted February 5, 2010 Author Share Posted February 5, 2010 Raask makes a set that is supposed to work. I saw somewhere where a guy bought a set on eBay off of a Maxim/Seca and mounted them to his XS360/400. Here is a link for some XS650 rearsets that would be easy to convert but they look like there mounted with bushings instead of bearings, I think you would have to e-mail to find out specifics: XS650 Rearsets I saw those, but I can't fathom why they are $300, ITS ALUMINUM!!! Link to comment Share on other sites More sharing options...
Runningdog Posted February 6, 2010 Share Posted February 6, 2010 For the tank dampers (and lots of other parts), try these folks. Link to comment Share on other sites More sharing options...
gs360 Posted February 14, 2010 Author Share Posted February 14, 2010 OK here's an update. I have the handlebar, mirrors, throttle body and new throttle cable ordered and they come in on Mon. I also have the tank painted (still have to do some trim) and the seat pan I pick up on Mon as well. Now I need a suggestion for tires. I was thinking either Avon Mark II or the Dunlop K81. I'm going for a Brat style bike, any suggestions? AND, is there any way to post a picture with out an HTTP link? Link to comment Share on other sites More sharing options...
BRB Posted February 14, 2010 Share Posted February 14, 2010 Is there any way to insert a picture with out an HTTP link? You have to download your pic to a photo sharing site like photobucket and then copy img code and paste to your forum post. Link to comment Share on other sites More sharing options...
gs360 Posted February 21, 2010 Author Share Posted February 21, 2010 ~ Drewpy How do I re-jet the carbs for a no mufflers? I got her to run but the left cylinder is popping, where as it wasn't with the muffler on. Any tips or tricks? Link to comment Share on other sites More sharing options...
BRB Posted February 22, 2010 Share Posted February 22, 2010 ~ Drewpy How do I re-jet the carbs for a no mufflers? I got her to run but the left cylinder is popping, where as it wasn't with the muffler on. Any tips or tricks? Here is a link that might help you get in the ballpark: http://www.motorcyclecarbs.com/Motorcycle_Carburetor_Jetting__W7.cfm Link to comment Share on other sites More sharing options...
Moderator drewpy Posted February 22, 2010 Moderator Share Posted February 22, 2010 Here is a link that might help you get in the ballpark: http://www.motorcyclecarbs.com/Motorcycle_Carburetor_Jetting__W7.cfm good link that Link to comment Share on other sites More sharing options...
gs360 Posted February 23, 2010 Author Share Posted February 23, 2010 grumble grumble grumble curse curse curse!!! Dropped the bike and dented the tank. OK, now the real question, When the bike is running I have exhaust coming out the Head Gasket. Is this most likely because it's not tight enough or did I blow it running with out an air filter (not driving, just in the garage checking the engine, starter, timing, ect...) ...I'm completely lost jetting the carbs. Does the measurement mean turns or the jet size? EDIT: NM I did some more research, I figured it out. BUUUT what size are the OEM jets? And as per the web site: 2 for no muffler, 2 for individual intakes, and 2? for no filter (panty hose filter really) Link to comment Share on other sites More sharing options...
