dan28 Posted January 16, 2010 Share Posted January 16, 2010 i bought my bike as an unfinished project its xvs 125 the previous owner has removed the indicaors an switch gear i have a complete wring loom for a xs 250 it comes with switch gear an all indicators what will the easyest method of fitting them be the loom on my bike has been chopped in the past i dont know what any of the wires are for could i wire the xs ignition switch loom to a live an then just chop off what i dont need or is there an easyier way ? Link to comment Share on other sites More sharing options...
Moderator drewpy Posted January 17, 2010 Moderator Share Posted January 17, 2010 easiest way would be to get a xvs loom. the xs250 will be nothing like it, as it carries different electrical components due to its age!! Link to comment Share on other sites More sharing options...
dan28 Posted January 17, 2010 Author Share Posted January 17, 2010 easiest way would be to get a xvs loom. the xs250 will be nothing like it, as it carries different electrical components due to its age!! i gave looking for a xvs loom they are rarer than hens teeth could i not use run a live to the switch gear an wire it that way Link to comment Share on other sites More sharing options...
Moderator drewpy Posted January 17, 2010 Moderator Share Posted January 17, 2010 i gave looking for a xvs loom they are rarer than hens teeth could i not use run a live to the switch gear an wire it that way would the xvs250 up be better? have you tried here Link to comment Share on other sites More sharing options...
dan28 Posted January 17, 2010 Author Share Posted January 17, 2010 would the xvs250 up be better? have you tried here thanks for that but i reckon it wont be cheap also the ignition switch startter horn an both lights are on different switches so i would have to rewire all these all i really need is a simple wiring diagram to show how the switch gear is wired to the indicators ? Link to comment Share on other sites More sharing options...
